02-03-2019
13:08
11:25
02-03-2019
13:08
11:25
I cannot seem to get any type of notifications on my Fitbit, I have tried to go into notifications but there is no options for texts or anything other than Fitbit messages. I have a Galaxy Note 8 so it should work. What can I do to fix this?
02-04-2019 02:07
02-04-2019 02:07
@BroadwayAngel3 you're looking in the wrong place. In the Fitbit mobile app, please tap on Charge 3 icon, then scroll down to Notifications. Set up everything there. Btw, as you're using Samsung, don't forget to enable messages preview on your screen in your phone settings or you will not be able to read notification text on Versa. Versa will display only what's visible in your phone's notification centre on the screen.
Best Answer02-04-2019 02:07
02-04-2019 02:07
11:28
08:45
02-04-2019
11:28
08:45
A warm welcome to the Community @BroadwayAngel3 and @Marrrmaduke thanks for the input.
If you are having issues with your notifications, I recommend taking a look at the following help articles and follow the instructions provide:
Let me know the outcome. ![]()
Best Answer01-10-2020 13:49
01-10-2020 13:49
That doesn't work ... I will return charge if it doesn't work
Best Answer01-10-2020 14:06
01-10-2020 14:06
That does not work
10:38
08:15
01-13-2020
10:38
08:15
Welcome to the Community, @deacnsteve.
Thanks for troubleshooting this notifications and for letting us know about it. We are aware of the problem and are working to resolve it as quickly as possible, sorry for any inconvenience it's caused and appreciate your patience and look forward to getting you back on track.
Please let me know if there's anything I may do to assist you in the meantime.
