06-06-2020
09:01
10:34
AlejandraFitbit
06-06-2020
09:01
10:34
AlejandraFitbit
My Fitbit is saying I’ve hit my goal but I know I haven’t and the app is saying the correct amount of steps such as I left for my walk on 5,300 steps walk for 10-15mins and I’ve hit 10,000 when I actually hit my real steps it will go off again to say I’ve hit 10,000. Could just need restarting but a bit annoying if I have to has have had other issues in past, it’s only 6 months old.
11-11-2020 10:35
11-11-2020 10:35
Welcome to the Community, @HannyD24.
I understand how are you feeling. For tips about improving accuracy, I recommend checking the help article: How accurate are Fitbit devices?.
Several things can affect the number of steps your Fitbit device records, including where you place the device, if you wear it on your dominant or non-dominant hand, and your stride length. If you're pushing a stroller or shopping cart, try putting your device in your pocket or use GPS to record your activity, if possible.
If it still seems like your device is undercounting or overcounting steps, try a step test. While you perform your step test, make sure you:
-Walk at a normal pace
-Don’t hold anything in your hands
-Put your arms down at your sides, swinging naturally
-Count 1 step for each foot
-To avoid getting an additional step when you bring your feet together, after you reach 100 steps:
Here’s the step test:
Let me know the outcome.
