05-14-2024
00:46
04:13
05-14-2024
00:46
04:13
Hi there,
The screen on my fitbit charge 3 stopped working, after chatting the fitbit helpdesk and trouble shooting they offered to replace it. I sent my broken fitbit to them and and a week later a refurbished charge 3 arrived. I plugged in the new fitbit with the charger received and experienced the same issue. After charging for about 3 hours there was still only a black screen. If I held the side button down I could feel it vibrating but nothing on the screen. I tried to connect to it using the app, my phone was able to locate it and the app asked for a pairing code however the code is to appear on the fitbit screen and this was just black. I chatted the help desk again and did some trouble shooting. They concluded that it was broken and offered to replace it, a week later the replacement arrived and I expereinced the same issues. Now I have 2 broken refurbished fitbits. Has anyone experienced this before or have a fix
Hello @Stephanie_carri
I moved your post from the Fitbit.com Dashboard forum to the Charge product help forum since your issue isn't related to the Fitbit on-line dashboard. Hopefully, someone here will be able to help you.
