10-13-2020
02:55
10:13
10-13-2020
02:55
10:13
I think there is an ongoing issue with Charge 3 screen. Mine is getting dim for the past 1 week..and it is getting worse by day. And yes it is not in sleep mode, and my brightness is set to normal. I also has the latest firmware update. I have been using it almost 2 years, got it in Nov 2018 for my birthday.
I cannot even see the clock properly now. It is darker at the center and upper part of screen. I think Fitbit has to do something regarding this as many people are complaining the same. Fitbit team, please kindly assist me in this matter. Thank you.
Moderator edit: format
10-14-2020
11:43
07:47
10-14-2020
11:43
07:47
Hi @Lenepawida, welcome to the Fitbit Community forums.
Thank you for the information you've provided regarding the problem with the screen of your Charge 3.
Before considering other options, please make sure that you've tried the standard restart procedure described here. If you continue to experience the same problem, please follow the steps listed here below to complete the long restart procedure:
In addition, please try changing the clock face option on your Charge 3 and make sure the Sleep Mode feature is turned off, this has been useful for some users as well.
Please keep me posted on the outcome.
Best Answer10-14-2020 13:39
10-14-2020 13:39
I was having the same issue - started two days ago while traveling. I completed the steps above and it fixed the problem. It is no longer dim and working properly.
thanks!
Best Answer10-20-2020 06:19
10-21-2020 07:46
10-21-2020 07:46
Too bad it doesn't work for me..
08:42
09:35
DavideFitbit
10-21-2020
08:42
09:35
DavideFitbit
I am now having this problem.. Did the steps but it is still dim..
Any new advice..?
I love my Fitbit Charge 3 and sure can not afford a new one yet as this is just over a year old..
10-21-2020
09:34
07:51
10-21-2020
09:34
07:51
Thank you for your reply and for confirming that you already tried all the steps suggested earlier @Lenepawida,
I've gone ahead and sent your information to the Customer Support team for further assistance, so you should be getting a reply soon.
@wzdjodie, besides the steps suggested earlier, could you please also confirm if your Charge 3 is not in Sleep Mode?
Please keep me posted.
10-21-2020 09:48
10-21-2020 09:48
Best Answer10-23-2020 06:13
10-29-2020 11:09
10-29-2020 11:09
Hi David, I am experiencing the same problem. I have used Fitbit Charge 3 for 2 years now and since last whole month my screen is so dim I can hardly see the time, forget about messages. I have tried all the above steps you suggested and it is still very dim.
Please help me fix my Fitbit.
Thank you
10-29-2020
13:18
08:36
DavideFitbit
10-29-2020
13:18
08:36
DavideFitbit
My Fitbit has been getting dimmer over the past few weeks. Hubby's is fine and daughter had hers longer is ok but mine is so hard to read. Tried changing clock face pics but still really dull.
Tried the above but to no avail.
Best Answer10-29-2020 13:39
10-29-2020 13:39
Same issue to mine as well. Purchase in Nov 2018. Restarted a few times with the long steps, but still dim. Please help.
Chi
10-29-2020
14:29
08:36
DavideFitbit
10-29-2020
14:29
08:36
DavideFitbit
I'm having the same issue, I thought something was wrong with my eyes. I pulled my old charge 2 out and its bright and clear as day. I have done the long reset and made sure the brightness is in normal. Still very hard to see. The Charge 2 is way better
Best Answer10-29-2020 15:53
10-29-2020 15:53
I tried everything but still very dim screen so I can’t see setting and not getting notifications. Kinda frustrating that these $150 units degrade after a year.
11-03-2020
08:39
07:47
11-03-2020
08:39
07:47
Hi, thank you for sharing this update and confirming that you already tried all the suggested troubleshooting steps mentioned earlier @Diva4ever @Jackieg66 @zoomzoom31 @Krystalkool @Tjb3cpa, and welcome to the new users in the Community. Sorry for the late response.
I've gone ahead and sent your information to the Customer Support team for further assistance with this, so you should be getting a reply soon.
Let me know if you have further questions.
Best Answer11-30-2020 05:50
11-30-2020 05:50
I'm having the same problem, has Fitbit given any real solution (apart from rebooting the device, which does not work)?
05:56
07:52
12-02-2020
05:56
07:52
Welcome to the Community forums @migulios.
Thank you for sharing that you've been experiencing the same with your Charge 3 device.
In addition to the restart procedure you mentioned, could you please also confirm if you already tried to disable the Sleep Mode feature on the devices's settings? The screen gets dimmer with this option and it prevents the device from vibrating and receiving notifications.
Keep me posted.
Best Answer01-21-2022 10:15
01-21-2022 10:15
I have followed and carried all your recommendations and the problem continues. It has been happening over the last 6 months. Barely readable even in a dark room.
01-21-2022 21:19
01-21-2022 21:19
This seems to be an ongoing issue. First time it has happened to me after many years of Fitbit use. Have tried the solution offered by Dave but no use. Scrreen too dark to view the stages. Does not seem to be giving off number of vibrations. Am desperate. Restarting is not effective
01-27-2022
08:15
07:52
01-27-2022
08:15
07:52
Welcome to the Fitbit Community forums, @MDs8r @Dark2lite.
I appreciate the information you've provided about this inconvenience with your Charge 5 and for confirming that you already tried all the troubleshooting steps suggested.
In this case, since you already tried all the recommendations mentioned here earlier and those available in the Community forums, I do recommend that you continue the communication with the Customer Support team for further assistance with this. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Thanks again for sharing your experience with this and your feedback.
See you around.
