04-17-2019
07:30
11:10
04-17-2019
07:30
11:10
I charged my Charge 3 overnight and when I unplugged it this morning it has these vertical lines running through the display. I have also found that swiping up/down on the screen is not working, I can only tap the screen to cycle through calories/steps/exercise/stairs/heart rate.
I restarted the Fitbit and I tried changing the clock face as recommended by other users, but with no luck. Can you please advise on what to do next?
04-18-2019
05:22
09:15
04-18-2019
05:22
09:15
Hey @shoregirl86, welcome to the Forums.
Thanks for troubleshooting this display issue by yourself. Since the restart process didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
In the meantime, let me know if you need anything else.
Best AnswerHey there! I'm having the same issue mentioned above, and have also tried to solve it in my own with no luck. How did this get fixed? Is there anything I can do?
Best AnswerI'm thinking that the charge 3 is a lemon. I haven't received a reply to fix mine when I reached out for support, or an offer for a replacement.
After charging, I also have vertical lines running through my screen. What fix is recommended?
