03-26-2019
12:23
06:16
AlejandraFitbit
03-26-2019
12:23
06:16
AlejandraFitbit
My Charge 3 screen is excessively dim, even with a full charge. I've tried restarting it with no result. It will occasionally come on bright but after a few seconds it's dim again and I can't get it back. This is indoors and is still difficult to read. Outside with any amount of sunlight, it's impossible to read.
04-28-2020 15:09
04-28-2020 15:09
I bought a Samsung Active. $150. Sad to leave Fitbit since I've had one since they first came out.
04-28-2020 15:48
04-28-2020 15:48
I might finally consider Apple Watch. Was offering free from work for a years but started with FitBit
04-29-2020 18:41
04-29-2020 18:41
04-29-2020 19:06 - edited 04-29-2020 19:07
Agree. As there is no any FitBit responses to help with defected product, I can't wait to try Wyze Band. $25 only, and if any issue, I don't care buying new one once a year - compare to $150 for Charge 3 which stays for 14 months.
hello, FitBit, it would be nice to hear back from you
05-03-2020 13:52
05-03-2020 13:52
I have just started couch to 5k but sadly while outside I can’t see my screen. Tried fully charging it. Indoors it’s fine. Setting is normal which looks like the brightest. Anyway I can change this would be good to see my pace Heidi 🙂
05-03-2020 15:14
05-03-2020 15:14
05-03-2020 16:04
05-03-2020 16:04
If your Fitbit is still under warranty get it replaced now. This is the beginning of the end for your device. Once mine started having that issue it never improved.
05-03-2020 21:20
05-03-2020 21:20
05-03-2020 23:45
05-03-2020 23:45
Me too!
05-04-2020 04:16 - edited 05-04-2020 04:18
Hi to All who Posted on this issue . I have had this issue for quite some time and made an early post re the matter. So many have had the same issue and are angry, which I sympathise with. I made contact with Fitbit about a week or two ago and they have replaced my unit free of charge. I have had the original since November of 2018 - so it was out of warranty. I did have the offer of 50% off the Charge 4 but wanted to see if this new one would work over time, so went for the free replacement of the Charge 3. And I didn't want to spend more money on Fitbit if the next one was also unreliable. Also I live in Australia which has very clear laws about an item being '"fit for purpose" even if it is out of the warranty period (not being able to see a watch outside would make it not fit for purpose), so I would have had a case with the Government department Çonsumer Affairs. And if merchants don't comply with requirements then they can be banned from selling their products in the country. So not sure if it was that or not but well worth pursuing directly with Fitbit. Good luck everybody
05-04-2020 04:35 - last edited on 08-30-2020 20:13 by LiliyaFitbit
I live in the US and Fitbit offered me 25% off a new Fitbit because mine was bought 10/2018. I'm don't know what you did or said to them that they replaced yours but good for you. I'm very disappointed in the company. I've had a Fitbit for at least 7 years and probably longer than that. The fact they don't seem to acknowledge that the screen issue is a pervasive problem is disappointing. If it's a hardware problem admit it and come up with a plan to fix it. Sadly I'm leaving the Fitbit family. I now have a Samsung active watch. Same cost and it will hopefully last longer than 18 months that my Fitbit charge 3 did.
Moderator edit: format
05-04-2020 04:39
05-04-2020 04:39
totally agree. How can I adjust in settings when I can't see anything. The screen is totally black
05-04-2020 04:52
05-04-2020 04:52
Exactly you can't. Does mine still count steps, yes. Can I start and stop an activity from my device, no. I can from the app and I did that for a couple of weeks. But I shouldn't have to. I am very happy with my Samsung Active watch so far. I didn't get the Samsung Active 2, I bought the first one which is currently $150.
05-04-2020 16:09
05-04-2020 16:09
05-04-2020 16:34
05-04-2020 16:34
Had the same problem and feel the same way!
05-04-2020 16:39
05-04-2020 16:39
I have the Wyze band and it's ok but it still has some bugs that make it hard to use has a daily wear. The software portal works but is also in need of improvements. On the bright side the screen is color, bright and easy to read.
05-06-2020 06:01
05-06-2020 06:01
If you can't read it outside, I would guess within two weeks you won't be able to read it even if you are standing in a totally dark walk-in closet in your home. That is what happened to mine.
05-06-2020 07:16
05-06-2020 07:16
Charge 3 screen too dim can not see it
05-06-2020 16:01
05-06-2020 16:01
05-06-2020 16:26
05-06-2020 16:26
I finally took the plunge last week and bought an Apple Series 3 38MM watch and have absolutely NO regrets. If you're using an Apple phone it's the only way to go. Either the Charge 3 is overpriced or the series 3 is a great bargain. There is no comparison between the two devices. Hope this helps.
