03-26-2019
12:23
06:16
AlejandraFitbit
03-26-2019
12:23
06:16
AlejandraFitbit
My Charge 3 screen is excessively dim, even with a full charge. I've tried restarting it with no result. It will occasionally come on bright but after a few seconds it's dim again and I can't get it back. This is indoors and is still difficult to read. Outside with any amount of sunlight, it's impossible to read.
05-31-2020 06:02
05-31-2020 06:02
After trying to have it replaced 5 times already. I just tried it one more time and got a replacement finally. They just made me follow the troublehooting steps (it didn't work, of course) and sent me the replacement link.
05-31-2020 06:06
05-31-2020 06:06
05-31-2020 06:12
05-31-2020 06:12
Went for the replacement. I thought about the charge 4 but it's still on preorder.
05-31-2020 06:12
05-31-2020 06:12
Note in the UK the charge 4 is not included in the 50 percent off deal so be wary of clicking that option as there's no going back - which is exactly what I did intending to get a 4.....
05-31-2020 06:12
05-31-2020 06:12
05-31-2020 06:13
05-31-2020 06:13
05-31-2020 06:32
05-31-2020 06:32
Can you get the 50% on the versa 2 or do you know if it has to be a tracker.
thanks
06-02-2020 13:12
06-02-2020 13:12
I have had my charge 3 for 9 months now. It was a special birthday present last August and I love it.
so disappointed that the display is now dull/ patchy and not visible at all in sunlight. I have tried all the suggestions on the forum and nothing works.
06-02-2020 15:58
06-02-2020 15:58
Make sure you immediately contact Fitbit online. Yours should still be under warranty and they should replace it. Mine was replaced even after the warranty period but I live in Australia and we have ‘fit for purpose’ laws here which give extra protection. Many have not been so fortunate. But if you have had yours for only 9 months it should be covered. And for your own sake don’t delay. They initially talked to me from their website (to Twitter) which I found strange but then they raised a request and I was contacted by email. I was offered a free replacement for a Charge 3 or 50% off a Charge 4. I took the free replacement and so far so good. Just a month now. Good luck.
06-02-2020 16:22
06-02-2020 16:22
I have done the recommended steps, along with a reboot. The screen is so dim, even in a darker room. I am very disappointed.
06-03-2020 05:03
06-03-2020 05:03
Thanks so much for your advice it is much appreciated!!
Bit tricky at first for me to make contact as I am not on social media but my teenagers helped and I made contact with Fit bit and they are sending a replacement Charge 3.
I hope I have better luck with this one as up until this issue, it was working fine.
06-03-2020 07:01
06-03-2020 07:01
06-05-2020 16:31
06-05-2020 16:31
Thank you for the info, however, no matter how i swipe, i can't get to settings. Ant other way to achieve a brighter setting?
06-07-2020 07:33
06-07-2020 07:33
06-07-2020 16:12
06-07-2020 16:12
I Have the same problem and try to adjust it in the setting but it does not get any better, still too dark to see
06-08-2020 00:33
06-08-2020 00:33
morning
i got in touch with support because my watch was too dim. It has now been replaced and is so much better.
06-09-2020 10:24
06-09-2020 10:24
I can't even see the settings to change them, it's so dim
06-09-2020 10:26
06-09-2020 10:26
I have reset the device and it still is unreadable
06-09-2020 10:39
06-09-2020 10:39
If it's still under guarantee, I would get in touch with support because they replaced mine and it's so much better.
06-09-2020 11:07
06-09-2020 11:07
Has this been resolved? My dim setting is black and normal is now dim.. and auto does nothing but stay dim. I’ve tried a hard reset and restart...
