03-26-2019
12:23
06:16
AlejandraFitbit
03-26-2019
12:23
06:16
AlejandraFitbit
My Charge 3 screen is excessively dim, even with a full charge. I've tried restarting it with no result. It will occasionally come on bright but after a few seconds it's dim again and I can't get it back. This is indoors and is still difficult to read. Outside with any amount of sunlight, it's impossible to read.
05-23-2020 15:18
05-23-2020 15:18
my screen is to dim to see even inside .I always kept it on normal .now I can't see anything
05-23-2020 15:42
05-23-2020 15:42
I live in the U.S. and it was still under warranty. I used twitter to complain and got a response within a few hours. I DM them and they checked my warranty and sent me a new one within a couple of days.
05-23-2020 16:14
05-23-2020 16:14
05-23-2020 19:08
05-23-2020 19:08
You need to contact Fitbit directly.
05-23-2020 23:36
05-23-2020 23:36
I have the same issue, tried everything possible but it still dim. I have out the clock face onto the biggest numbers so I am at least able to see it a little in daylight. This clearly is an issue for many people when is fitbit going to do something about it. All other functions are working g perfectly. This is so annoying
05-24-2020 06:27
05-24-2020 06:27
I love the Fitbit charge but it’s impossible to use, especially outside you just can’t see the screen. It definitely needS an option to increase the brightness.
05-24-2020 06:30
05-24-2020 06:30
On the Fitbit charge 3 does anyone know how long the warranty is. I bought it December 2018.
Thanks
05-24-2020 06:34
05-24-2020 06:34
The warranty duration depends upon what geographic area you purchased it in. The EU/UK has a 2 year warranty.
05-24-2020 07:14
05-24-2020 07:14
I’m from the uk.
Thank you.
05-24-2020 08:50
05-24-2020 08:50
My charger 3 is the same, Can only see it when inside the house .fitbits are absolutely rubbish, had trouble with syncing , notifications Switching it self off and now this , it’s 17 months old Shame on you Fitbit for making rubbish merchandise .who wants to buy something that you have to constantly delete the app turn your Bluetooth on and off turn your phone on and off wouldn’t buy another one , and definitely wouldn’t recommend .
05-24-2020 09:41
05-24-2020 09:41
@Bel3: It should be as simple as making contact with Fitbit support and getting a replacement. If you are logged in to their site, there should be an online Chat option available to you.
They have been helpful in the past to me. The first time I needed a replacement the online chat took nearly an hour. The last time (I've needed 5 or 6 replacements for various reasons), the chat took less than 10 minutes.
What they don't realise is that they don't just lose one customer for every faulty device that they won't support (hopefully in your case they will), but they lose multiple potential customers due to the spread of the word.
05-24-2020 09:55
05-24-2020 09:55
05-24-2020 10:36
05-24-2020 10:36
05-24-2020 10:53
05-24-2020 10:53
05-24-2020 10:55
05-24-2020 10:55
05-24-2020 17:01
05-24-2020 17:01
Yes - they replaced free of charge. By the time I contacted them directly I had had the watch for 18 months.
05-25-2020 08:03
05-25-2020 08:03
05-25-2020 08:50
05-25-2020 08:50
Thank you. I will ring them tomorrow to see if they will replace my watch.
05-27-2020 20:50
05-27-2020 20:50
Thanks! This helped me with that issue. The boyfriend's son kept tapping my screen and managed to change the brightness.
05-29-2020 17:33
05-29-2020 17:33
Whatever happened to the "customer for life" if they would only replace your Fitbit (which, apparently they are in the process of doing)????
