07-13-2020
08:03
08:40
07-13-2020
08:03
08:40
Hello, Got my charge 3 at end of May 2020 and screen was not as bright as charge2. Now, a few weeks later, I can no longer read the screen in any kind of light. I have done all the resets and reboots to no avail!
Even tried a different clock face. Device is not usable in this condition.
07-13-2020 09:31 - edited 12-22-2023 09:25
Hi there @lzvt4d, welcome to the Community Forums. Thanks for the details provided in your post about your Charge 3's screen brightness and for taking the time to fix it prior to posting here.
Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
I'll be around if you have any questions present.
09-09-2020 03:28
09-09-2020 03:28
My Screen as well tried the restart nothing works!!!
09-24-2020 20:29
09-24-2020 20:29
I just had the same thing happen. After I tried all resets, I read through many of the 80+ pages of a similar post. One person said to swipe 5 times to get to the settings page. I also tried going in a totally dark room, and I could see it a little. After swiping - It was 4 times for me, you tap the top. I had to tap it twice, and it went back bright. I did this OFF the charger. Good luck.
09-28-2020 06:47
09-28-2020 06:47
Please help me too. I have tried all of the reboot tips etc in the forums about a dim screen with no success. I can only see me screen now in a total darkened room.
10-12-2020 09:00
10-12-2020 09:00
Hi my charge 3 light so dim can’t see anything now
11-12-2020 21:37
11-12-2020 21:37
I have exactly the same issue on Normal its hard to see in a dark room and auto is almost invisible in a completely dark room. Really frustrated. Wasn't always like this
11-13-2020 12:54
11-13-2020 12:54
This is happening to my charge 3 too, what is the solution?
11-14-2020 05:48
11-14-2020 05:48
The charge 3 dim screen issue is very disappointing. I have reset several times added upgrades reset again and still cannot read the screen. The charge 3 is basically useless. Why can’t Fitbit support provide an update or solution for this annoying problem
11-18-2020 08:48
11-18-2020 08:48
This worked for me
Best Answer12-03-2020 02:46
12-03-2020 02:46
I am having this issue as well. Did they provide a solution for you?
Best Answer12-03-2020 03:21
12-03-2020 03:21
I am also having the problem. It is really irritating and a serious problem now!
03-12-2022 09:49
03-12-2022 09:49
This is not an answer. Like me, Lots of users left with unusable charge3. A fit bit rip off. Never ever purchase Fitbit again.
03-12-2022 14:14
03-12-2022 14:14
Same here. It’s unusable.
