01-21-2021 15:20 - last edited on 01-22-2021 10:36 by LiliyaFitbit
My Charge 3 is a year old. It no longer can scroll off the home clock screen. It does scroll on the setup sleep, DND and wake functions. Is something turned off?
01-22-2021 10:39
01-22-2021 10:39
Welcome to the Fitbit Community, @BChoctaw.
Thank you for sharing the details of the issue you’re experiencing. I recommend trying the following:
I'll be around if you need further help.
Best Answer01-22-2021 11:13
01-22-2021 11:13
Thanks for the reply to this issue.
I can not get the device to restart when plugged into the charging cable on several attempts. I have tried to do a full reset as well but I can’t get to the settings screen as it won’t move from the clock screen.
I have also tried a variety of clock face changes without any success.
Any further suggestions? Thanks.
Best Answer01-22-2021 12:55
01-22-2021 12:55
Welcome to the Fitbit Community, @Mhutch2079.
Thank you for joining the thread and sharing the details of the issue with your device. I appreciate your troubleshooting efforts and recommend doing a long restart:
Let me know how it goes.
Best Answer01-22-2021 13:16
01-22-2021 13:16
Device vibrates when connected to charger but has a black screen
When button is pressed and held the clock appears and one vibration occurs
After 8-10 seconds there are four vibrations with the screen black
No change after 15 seconds or more
Further button presses bring up the clock but the scrolling issue persists
Best Answer01-22-2021 13:35
01-22-2021 13:35
Thank you for the update, @Mhutch2079.
I am sorry to hear the issue persists, thank you for your efforts. I've sent your information to the Customer Support team so they can get in touch with you and provide further assistance. You should be getting a reply soon.
I'll be around if you have any questions.
Best Answer01-22-2021 13:43
01-22-2021 13:43
Thanks so much for your efforts and prompt responses. Have a great day.
01-22-2021 16:10
01-22-2021 16:10
Thank you for your response, @Mhutch2079.
I appreciate your feedback and look forward to getting you back on track. Please take into consideration that our Support team may take a bit longer to get back to you due to recent events affecting our operations. I appreciate your patience and understanding.
Keep on visiting the forums.
