04-09-2021
10:42
11:00
WilsonFitbit
04-09-2021
10:42
11:00
WilsonFitbit
I have not turned on my Fitbit for months, now I have decided to charge it and it has been stuck on a screen with the Fitbit logo and 001. I have tried holding down the side button for it to restart but it doesn’t buzz, nor restart. Does anyone have any similar problems and solutions? Thank you.
Moderator edit: subject for clarity/label
04-09-2021 10:46
04-09-2021 10:46
I've moved your post to the correct forum as it states Charge 3 in the title and you posted it in the Versa 3 forum.
04-09-2021 10:48
04-09-2021 10:48
Thank you! I have noticed that I did that too.
04-09-2021 11:12
04-09-2021 11:12
Hello @mont8374. Welcome to the community forums! @SunsetRunner It's great to see you around and thanks for your help!
@mont8374 Please make sure you're restating your Charge 3 as suggested by this help article. If that doesn't help, I recommend performing a long restart, by following the steps below:
Hope this helps.
Best Answer04-09-2021 11:32
04-09-2021 11:32
i'm having the same problem, the regular restart didn't do anything. and when i've tried the long restart there was no battery icon with two vibrations, only a smiley face & then blank screen. the device only comes back on with the 001 error code again 😕
Best Answer04-10-2021 02:21
04-10-2021 02:21
I'm the same tried the long restart and doesnt show anything just a blank screen then after a while the error code 001 shows. Its vibrates when I hold it down that's it
04-15-2021 09:36 - edited 04-15-2021 09:37
Hello @simplyalli @RyanR26. Welcome to the community forums.
I'm sorry to hear this and thank you for the information and for following the troubleshooting steps. If the inconvenience has persisted, the best way to get help is to contact our Support Team for further assistance. You can contact them through chat or over the phone. Click here to get connected.
See you around.
