02-06-2020
12:34
15:05
02-06-2020
12:34
15:05
My Charge 3 has stated about double the amount of steps I have actually done for the past 2 days. When I’ve added up the amount of steps on each of the 15 minute breakdowns, I am getting about the number of expected steps so why is my overall not equaling the breakdown? Any ideas?
thanks
02-07-2020 06:20
02-07-2020 06:20
It's great to see you here, @matto82.
For tips about improving accuracy, I recommend checking the help article: How accurate are Fitbit devices?.
Several things can affect the number of steps your Fitbit device records, including where you place the device, if you wear it on your dominant or non-dominant hand, and your stride length. If you're pushing a stroller or shopping cart, try putting your device in your pocket or use GPS to record your activity, if possible.
If it still seems like your device is undercounting or overcounting steps, try a step test. While you perform your step test, make sure you:
-Walk at a normal pace
-Don’t hold anything in your hands
-Put your arms down at your sides, swinging naturally
-Count 1 step for each foot
-To avoid getting an additional step when you bring your feet together, after you reach 100 steps:
Here’s the step test:
Let me know how it goes. 🙂
