05-11-2020
20:45
09:35
05-11-2020
20:45
09:35
Go on a daily walk with my husband. He is 6’3” and I am 4’11”. I used to always have more steps than him which is expected. About 2-3 weeks ago my Fitbit started showing I am taking less steps than him. Today showed almost 1500 steps less than his. We walk side by side so how is this possible? Can I fix this?
09-04-2020 11:20
09-04-2020 11:20
Welcome to the Community, @Debrthomas.
For tips about improving accuracy, I recommend checking the help article: How accurate are Fitbit devices?.
Several things can affect the number of steps your Fitbit device records, including where you place the device, if you wear it on your dominant or non-dominant hand, and your stride length. If you're pushing a stroller or shopping cart, try putting your device in your pocket or use GPS to record your activity, if possible.
If it still seems like your device is undercounting or overcounting steps, try a step test. While you perform your step test, make sure you:
-Walk at a normal pace
-Don’t hold anything in your hands
-Put your arms down at your sides, swinging naturally
-Count 1 step for each foot
-To avoid getting an additional step when you bring your feet together, after you reach 100 steps:
Here’s the step test:
Let me know the outcome.
