01-24-2023
06:48
16:55
01-24-2023
06:48
16:55
While visiting overseas, I could not get my Fitbit to work. It started buzzing one night while I was trying to get to sleep so I stopped wearing it and removed the app in the hopes that in the morning I could figure it out and reset it. I am having problems setting it back up again. I can get the smiley face when I press it for eight seconds. The Fitbit is detected but screen is blank and no code shows up. I have tried a long reset holding it for 15 seconds. Turning on and off Bluetooth, turning on and off my phone. Still it will not reset. when charging I do not see a battery icon . I can only get a smiley face but the rest of the time the screen is black no reset bar either when I press for 15 seconds my Fitbit is out of warranty. Please advise what other options I can try.
01-25-2023 16:58 - edited 01-25-2023 16:59
Hi there, @Callie62. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Charge 3 before reaching out.
As a first approach, I'd recommend leaving your Fitbit device charging at least 1 hour. Then, please check if your Charge 3 is displaying anything than the smiley face. If the smiley face has gone, let's try to restart your tracker once by following these steps:
If the above doesn't work, try the steps below:
If you can't get started with the Fitbit Charge 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
02-04-2023 17:45
02-04-2023 17:45
None of the above suggestions work. I still only get the smiley face but not a battery icon or anything else. The app says it recognizes the Fitbit but no code shows up on the screen and it’s black. I’m really missing my Fitbit to track my walking. What’s the next step?
