11-24-2021 18:44
11-24-2021 18:44
Within the last week my charge 3 has stopped vibrating with notifications. I have tried everything that I’ve found on these threads: checking that sleep/dnd is not on, quick and long reset, and checking the settings on my phone. Nothing worked. When I put it on the charger, it doesn’t vibrate. Is it possible for the vibration motor to quit working?
11-26-2021 06:47 - edited 11-26-2021 06:51
Thanks for getting back to us @SunsetRunner. Thank you for letting us know that you have checked that sleep/dnd are not on and tried restarts to make your Charge 3 vibrate.
Yes, it is possible that the vibration motor quit working because your tracker doesn´t vibrate at all. I noticed that you already got in touch with our Support Team.
Keep on visiting the forums.
11-29-2021 20:15
11-29-2021 20:15
I also have lost all vibrations on my Charge 3
Best Answer12-01-2021 11:12
12-01-2021 11:12
Thanks for getting back to us and for letting us know that your Charge 3 has lost all vibrations @KathyWay.
Have you already tried restarting your tracker:
Open the Charge 3 Settings app and tap About: Reboot: Device.
If your Charge 3 us still not vibrating:
Your tracker should now work normally. If your tracker still doesn't work after a restart, contact Customer Support.
