05-31-2020
22:45
05:34
AlejandraFitbit
05-31-2020
22:45
05:34
AlejandraFitbit
My Fitbit which is less than a year old suddenly started to get hot when charging. I had a low battery message, plugged it in, got smiley face and left it. I picked it up about half an hour later and it was very hot. I unplugged it and nothing works. Black screen I am using the original charging cable and there isn't a fault with the socket. Has anyone else had the same problem? I plugged it in again 2 days later ..screen came on for about 5 minutes and went off again. Have messaged fit it about 6 days ago but haven't received a reply!
09-17-2020
05:35
09:14
09-17-2020
05:35
09:14
Welcome to the Community, @Wardy123.
Our support team may be experiencing slight delays in customer response times because of the recent event going on. They are doing everything they can to ensure that you get a reply as quickly as possible. Since you have already contacted them, I recommend waiting for their reply. I know they will be glad to help you out and provide you a solution.
In the meantime, let me know if you need anything else.
