06-03-2020
17:29
16:20
06-03-2020
17:29
16:20
I am having two issues with the interval training setting on my recently purchased Charge 4.
1. The Move/Rest times are preset at 10 seconds each. I want to change the time to 30 seconds of work to 10 seconds of rest, but I can't seem to figure out how to change the time settings.
2. The Charge 4 does not vibrate when it's time to change from move to rest or vise versa. I want it to vibrate to alert me when to change movements/rest, etc.
My Charge 2 was already preset to do both of these things. I like the way it was set up for interval training. The Charge 4 presetting are just not as good and for some reason the custom settings elude me. Help with this is much welcomed and appreciated. Thank you!
06-04-2020 06:51
06-04-2020 06:51
Welcome to the Community, @L_banjo.
Regarding your interval training issue, by default, the interval workout consists of:
To set custom intervals:
Let me know how it goes. 🙂
06-15-2020 15:24
06-15-2020 15:24
Just got the Charge 4. I don't see an Interval option (Step 3). I'd like to set up Walk for 5min, Run 5k, Walk 5 min. Is that possible with the Charge 4? Thanks
06-15-2020 15:43
06-15-2020 15:43
06-15-2020 15:53
06-15-2020 15:53
Thank you. I see Interval Workout as a "+" option now.
Well, that's a bummer. My 7 yr old Runner Double app does this, but it's been getting buggy lately by dropping my run tracking. I was hoping to have Fitbit completely replace it.
06-28-2020 12:13
06-28-2020 12:13
Hi @qtrroy, welcome to the Community Forums. @t.parker, it's great to see you around and thanks for sharing your insight.
@qtrroy, I'm glad that you were able to add the Interval Workout as an exercise shortcut. As @t.parker, mentioned the Interval Workout is an option to track high intensity periods and rest times. I'm sorry for any inconvenience caused. Our team always takes every comment shared in the forums into consideration to improve our products and services, for that reason I'd recommend to submit this idea in the Feature Suggestions board so other members can vote for it. The more votes an idea receives, the better chance it has of getting the attention of the developers.
I'll be around if you have another question.
06-29-2020 16:34
06-29-2020 16:34
Hi Lizzy,
I've also got one of the problems listed by the original poster. I've managed to set my intervals, but I can't seem to get the Fitbit to buzz to notify me when to change between move and rest.
Could you advise how to make the Fitbit do this? Is this not a feature, is it a bug, or other?
07-12-2020 09:58
07-12-2020 09:58
I’m having this same issue, no vibration between intervals and the screen doesn’t light up either. Kind of defeats the purpose of having timed intervals ..
12-28-2020 07:57
12-28-2020 07:57
Hiya. Just got a charge 4. Trying to set up for run intervals but cant see Interval workout in exercise shortcuts and no + either. Can you help? I can see how to set laps but it is not clear where to set how many intervals or rest period.
Thank you
01-09-2021 12:48
01-09-2021 12:48
I have the same issue
01-25-2021 12:13
01-25-2021 12:13
Hei. I cannot edit or add more intervals. Seems to be a bug. I have a Charge 4 and a new iPhone SE. When i press edit i can only delete the rest time. This is seems like veru vital thing that should work. Also even finding the setting was difficult and none intuitive.
01-25-2021 22:22
01-25-2021 22:22
My fitbit used to vibrate during the interval training for each rest/move period. Since the update a few days ago it completely stopped doing that. I hope we both get the answer to that issue soon.
To change the interval you have to use the app on your phone, but I'm sure you've figured that out already.
02-01-2021 10:36
02-01-2021 10:36
Just did my first interval run with my new charge 4 and it didn't vibrate between intervals, I held it in view for the 3rd change just in case I'd missed it but nothing which makes it useless, I've just changed the settings to max vibrate which I'll try next run
02-01-2021 11:08
02-01-2021 11:08
Just discovered my exercise alerts were turned off doh, another thread pointed me to this, may need to turn off heart zone notifications too, both controls are on the watch under settings 😀
11-16-2021 12:39
11-16-2021 12:39
That did it!! Thank you!
For anyone still looking:
On the watch > settings > do not disturb > exercise notifications
02-18-2022 09:27
02-18-2022 09:27
I am having a slightly different issue. It does vibrate between intervals, but it is so slight and short that I often don’t feel it. I set vibrations to strong, and it didn’t make a difference. Is there any way to increase the length of time that it vibrates?
02-18-2022 14:41
02-18-2022 14:41
03-25-2022 06:05
03-25-2022 06:05
The app records the rest and move periods opposite to how it is shown on the device during the workout. So if i have a 30s move and 1 min resr period, the app shows it as 30s rest and 1 min move. This is very irritating and seems to be a result of a botched firmware update quite a while ago. Please fix this.
04-10-2022 02:34
04-10-2022 02:34
04-10-2022 12:47
04-10-2022 12:47
