08-02-2022
01:33
14:04
08-02-2022
01:33
14:04
Hello,
My Fitbit could not sync since morning, so I had try restarting my iPhone (on and off the Bluetooth as well), the Fitbit Charge 4 multiple times as well as updated my iOS to the latest 15.6 version.
Since the sync still didn’t work, I even deleted and reinstalled the Fitbit App multiple times. At the end, I removed Charge 4 from the app and try to set it up again. Then, I encounter the HTTP 403 error.
The Charge 4 keep prompting 4 digit code for the Fitbit App to connect however to no avail and the error code keep prompting (com.fitbit.HTTP error 403).
Appreciate your assistance on this sync issue.
08-02-2022 09:41
08-02-2022 09:41
Hello @Thryzachan
Hopefully I can help. It might be that you didn’t unpair your Charge 4 from Bluetooth before setting it up as a new device again. Let’s try these steps: (you will not losing any data setting your Charge 4 as a new device but it only saves data from your last successful sync)
08-02-2022 09:41
08-02-2022 09:41
Hello @Thryzachan
08-02-2022 21:21
08-02-2022 21:21
Hello @SunsetRunner
After following your steps, it did work.
My Fitbit is updated to its latest firmware after the successful sync (with the 4 digit code).
Thank you very much ☺️
08-03-2022 04:38
08-03-2022 04:38
😃 That’s fantastic news @Thryzachan! I’m happy to see it worked and your up and running again. Please consider marking my instructions on how to fix the issue as “best answer”. Doing so really helps others find answers quickly to issues they might be experiencing. I’d really appreciate it. I hope you have an awesome rest of your week and as always Happy Stepping!
