01-24-2025
07:06
07:58
01-24-2025
07:06
07:58
Everytime I connect my fitbit to the charger, it connects but within seconds it says "battery not charging". I've cleaned the device contacts as well as the charger and still get the same results
01-24-2025 08:03
01-24-2025 08:03
Hi there, @c668. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 4 is not charging properly. I understand your concern, I will do my best to help you with this!
As you may know, please note that there are some issues that affect this, being which power source is used and how clean the contacts are and how well the charger is seated. If you are charging your Charge 4 on the wall socket, try using another CE certified USB adapter for low energy devices.
To better assist you, please confirm that you've tried all tips and recommendations provided here Why isn't my Fitbit device's battery charging?
01-27-2025 11:53
01-27-2025 11:53
I tried 3 different usb adapters, but still get the same results. I only have the one fitbit charger though
01-28-2025 04:51
01-28-2025 04:51
@c668 Since all the steps you tried didn't work, you have a Charge 4 and report it's not charging properly I need additional information from you that would best be shared privately. I’m sharing a link to a form for you to fill out so we can look into this further.
This form is only meant for you to use, so let me know once you’re done. Click here to get access to it.
02-13-2025 06:54
02-13-2025 06:54
I didn't see this reply until now. I just filled out the form
