06-15-2023
05:50
07:55
06-15-2023
05:50
07:55
I've had my charge 4 paired with my new phone for a couple weeks. Starting a couple days ago, the app no longer connects to the device. I've restarted both the phone and the tracker (both the button restart and reboot from settings) multiple times. I've uninstalled and reinstalled the app. I unpaired the tracker and tried to add it as a new device. I get the four digit number to enter and nothing connects. It just says its taking longer than usual and stops trying.
Samsung Galaxy S23 Ultra
Android Version 13
Bluetooth is on and I see the tracker in the list of available devices.
I had to clear user data from the tracker to get it to connect, which is what I was trying to avoid knowing I'd lose the couple days worth of data since the last time I was able to sync. Once the device connected, I see I've lost 11 days worth of data from my account. Not a fan. The data was in my app until I unpaired.
06-17-2023 07:58
06-17-2023 07:58
Hi there, @GeorgeBronx. Thanks for stopping by in the Fitbit Community Forums and trying to troubleshoot the issue with your Charge 4 before reaching out. I understand where your concern is coming from.
As a first approach, I'd suggest making sure that your Charge 4 is no longer connected to your old mobile device as this might be preventing your Fitbit device to properly connect to your new phone.
With that being said, please follow the steps below in the order listed:
With the steps above, what I want you to do is to pair your Charge 4 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer06-20-2023 20:07
06-20-2023 20:07
I have tried all of the suggested steps, as well as deleting and reinstalling the app and redoing set up of my device. I've even turned off the Bluetooth on my laptop to make absolutely sure that Fitbit - Phone is the only Bluetooth running in the house.
It still won't connect.
It hasn't synced since the morning of 15 June and its now mid afternoon on 21 June.
I'm on a Samsung A24.
