08-14-2023
01:56
03:36
08-14-2023
01:56
03:36
Hi, my Charge 4 which I've been using fine for ages has decided to stop syncing with the app.
I had stopped using it in May, but decided to use again today. Charged it up and it wouldn't sync no matter what I did.
Ended up just deleting the device and trying to set it up again. My phone sees the device, but won't get past the part where I enter the code. I've tried disconnecting my Bluetooth, resetting the device, followed all the instructions I've been able to find, but it's still not pairing.
Would love some help as I've been successfully using this for ages, not sure what happened!
08-14-2023 03:39
08-14-2023 03:39
Hi there, @girlafraid82. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Charge 4 before reaching out.
In addition to the steps you've done, please try the following in the order listed (even if some of them you've tried already):
With the steps above, what I want you to do is to pair your Charge 4 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer08-14-2023 05:16
08-14-2023 05:16
Hi, thanks for the reply!
Unfortunately the steps didn't work, but I decided to go one step further and delete my user data from the device completely. This has allowed it to sync so it's working again!
08-14-2023 05:24
08-14-2023 05:24
@girlafraid82 Awesome! I'm glad to hear you managed to solve the issue with your Charge 4.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
Best Answer08-17-2023 02:51
08-17-2023 02:51
This happens to me too! Keep an eye on it and make sure it’s syncing to your phone each night. If it isn’t then you may need to erase your data again. It’s a pain.
