05-21-2020
14:27
16:20
05-21-2020
14:27
16:20
Charge 4 won't sync to Windows 10 laptop. I've done;
* Stopped bluetooth
* started bluetooth
* restarted Charge 4
* Start fitbit application
Sync starts and then hangs.
05-21-2020 14:30
05-21-2020 14:30
Rebooted PC and went through all stop / start restart and reboot scenarios and it refuses to sync to Windows 10 laptop. What kind of garbage is this? An idea would be to add fitbit syncing as an exercise since I seem to spend as much time trying to sync the fitbit as I spend exercising!
05-21-2020 14:33
05-21-2020 14:33
You want to charge a premium for things like SPO2?? WTF, you can't get the non-premium to work, why would I pay extra so it still wouldn't work! Maybe if you got some real developers it would help. Yes, I'm pissed!
05-21-2020 14:37
05-21-2020 14:37
Having this same problem with my Versa 2. Seems to be a problem with fitbit in general. I read plenty of these type problems and fitbit gives the same old responses. Maybe if this was escalated or some real application developers were hired these would get fixed.
05-22-2020 00:39 - edited 05-22-2020 00:40
05-22-2020 03:44
05-22-2020 03:44
That Fitbit Store page is incorrect. It syncs with iOS 12.2 and up, not Mac OS X 12.2. There is no Mac OS 12.
And, yes, Fitbit ended syncing with Windows 10 when the Versa 2 was released.
Laurie | Maryland
Best Answer05-22-2020 07:44
05-22-2020 07:44
@Giampi71 If what you say is true why does the Windows fitbit application list both the Charge 4 and Versa 2 in the "Set Up a Device" list and why has my versa 2 synced with Windows 10 on my laptop in the past? Seems like fitbit needs to come clean and make a clear statement that new devices like the charge 4 and versa 2 are not compatible with windows 10 on a laptop with built in bluetooth. And remove those devices from the windows 10 fitbit application device setup.
05-22-2020 08:36
05-22-2020 08:36
@Giampi71 @LZeeW From the Microsoft store description of the fitbit application;
"SYNC WIRELESSLY: Fitbit trackers sync your stats to computers and 200+ leading devices so you can continuously track your progress without needing to plug in"
This needs to be updated to explain which fitbit devices are not supported for this application from the Microsoft store for Windows 10 computers.
05-22-2020 15:11
05-22-2020 15:11
You're right @w3wilkes , there are errors and contradictory information in the documentation, only Fitbit can clarify it.
06-03-2020 11:49
06-03-2020 11:49
Hello guys, thanks for your participation in the Forums.
I understand how are you feeling and appreciate all the efforts in trying to fix this syncing issue. If you want to sync your device with your Windows 10 device, check the following:
REQUIREMENTS
Let me know how it goes. 🙂
06-03-2020 14:45
06-03-2020 14:45
@AlejandraFitbit Are you now saying that Charge 4 is compatible with Windows 10? Because store description on all other documentation state it is not. Thanks for clarifying.
06-04-2020 13:33
06-04-2020 13:33
@AlejandraFitbit When you tell JWPain that it should sync with Windows 10 does that also apply to my Versa 2? I've gone through everything in this response multiple times and my Versa 2 refuses to sync. There's definitely a problem either with the way fitbit is doing bluetooth on fitbit devices or there's a problem with the fitbit app from the Microsoft store. The only date info I can find for the fitbit app in the MS store is December 2012 which is eons ago in computer time so there's probably been multiple changes to both Windows and bluetooth on PC laptops. Maybe it's time to revisit the fitbit app for Windows.
Best Answer06-05-2020 07:10
06-22-2020 18:50
06-22-2020 18:50
I can get it to sync on only one Windows 10 PC at a time. When I try to since on both my home and office Windows 10 PC it will only sync on one. I can get it to sync on the other if I re-pair it This is frustrating. I did not have this problem with the Charge 2 my new Charge 4 replaced.
Best Answer06-23-2020 05:17
06-27-2020 11:04 - edited 06-27-2020 13:30
07-06-2020
11:07
09:06
07-06-2020
11:07
09:06
It's great to see you here, @BadgerBacker.
I understand how are you feeling and appreciate all the efforts in trying to fix this syncing issue. Thanks for the attachment too. Are you still having problems syncing your unit after you followed those steps?.
I hope to hear from you soon.
Best Answer07-06-2020 11:28
07-06-2020 11:28
@AlejandraFitbit You already know from other Community threads I have done all that and you've also acknowledged the issue is Charge 4 was designed to NOT be compatible with a Windows 10 PC.
Best Answer08-25-2020 12:44
08-25-2020 12:44
i agree 4 fitbit but the first one that can't snyc tried shutting thing off uninstalled twice wth
Best Answer08-31-2020 09:58
08-31-2020 09:58
It was a great day in this posting: Will it happen again?
07-22-2015 10:44 - last edited on 07-19-2016 12:32 by LenaFit
Windows Fitbit users!
Today, we announce the new and improved Windows 10 Fitbit app! We’ve taken the new Windows 10 operating system as an opportunity to craft an app that improves the Fitbit experience! After seeing what was possible with Windows 10,
Until now with only support for
. So,
Does Fitbit plan to support Windows 10 again for its current and future devices?
Rather than requiring a Google search on “Smart watches that support windows 10”.
Can you list the Fitbit devices that support Windows 10?
