05-27-2020
23:57
16:20
05-27-2020
23:57
16:20
I have had my Charge 4 for a few days and it worked perfectly until this morning and now it won't sync. I sync it to an iPhone X and tried turning Bluetooth on and off and it cannot recognize the Charge 4. Any ideas what to do?
05-29-2020
09:35
04:22
05-29-2020
09:35
04:22
Welcome to the Forums, @AvrilAdam.
Thanks for troubleshooting this syncing issue. I am glad to hear that this has been resolved by removing and adding the device from your Bluetooth's settings. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up!
06:43
04:23
08-06-2020
06:43
04:23
Hey @Wisteria23, it's great to welcome you.
I appreciate the efforts in trying to fix this syncing and thanks for sharing the steps you did in order to fix this problem. I know our friends will find the information here really helpful.
Happy stepping!
Best AnswerIssue with that is you lose all unsynced data, and as this seems to be an ongoing issue it's pretty poor from fitbit it'd put me off buying another.
so, basically.. every single week when my charge 4 gets funky and won't sync I have to remove from bluetooth and reconnect?! How about FItbit fix it instead so we don't pay $100 for something that infrequently works?!
I have owned my Charge 4 for a week, updated the new firmware and followed the instructions for forgetting my device on my iPhone’s Bluetooth. Have rebooted the app, have removed my watch from my fitbit app, etc... My Charge 4 loses its sync sometimes 2-3 times a day, works well for a day then loses it again the next day. My old Charge 2 syncs like a charm every time I run it. Sadly, this device is going back to Costco. Don’t know if I will replace it.
The Fitbit Charge 4 is junk. I have had to call and get help multiple times with different issues. I wasn't getting notifications. Got that resolved for a couple of days. Now not getting notifications again and now it won't sync. I'm done with Fitbit and will find another tracker.
07-28-2021
15:07
04:23
07-28-2021
15:07
04:23
Welcome to the Fitbit Community, @Lee0826 and @JRENNER.
@Lee0826 I am sorry that you are going through the same situation. I appreciate your troubleshooting efforts and recommend trying the following:
Choose your device and follow the on-screen instructions to continue.
You can find our complete troubleshooting tips in Why can't I set up my Fitbit device?
@JRENNER I appreciate your participation in the Forums and sharing the issues you've had with your device and your experience with Customer Support. I understand how you are feeling and appreciate your feedback. I am sure our Support team tried their best to help you, each case is reviewed individually and a solution that's being provided is based on the Fitbit Warranty. If you still need help, please feel free to contact our team back as they already have all the details and special tools to continue assisting you.
Hope this helps.
Best AnswerDidn't help at all. Gobbely-**ahem**!
07-28-2021
17:09
04:23
07-28-2021
17:09
04:23
Welcome to the Fitbit Community, @Valmilliken.
I understand how you are feeling and appreciate your troubleshooting efforts. I recommend connecting your device to the charging cable and confirming if it is updated to the latest version: How do I update my Fitbit device? For complete troubleshooting tips, see Why won't my Fitbit device sync?
Hope this helps.
Best AnswerHi,
I have a similar problem,I have to restart the mobile to get it to sync, have you reloved it?
16:42
04:23
07-29-2021
16:42
04:23
Welcome to the Fitbit Community, @A-L-E-X-50.
I am sorry that you are going through the same situation, thank you for sharing your experience. I was able to see that you have already contacted our Support team regarding this. I recommend you continue working with them since they have already all the details and special tools to continue assisting you. I know they will be glad to help you out and provide a solution.
See you around.
Best AnswerThis doesn't work. However, I bought a dongle and can synch to my dashboard thru the app on my windows PC. The problem is the mobile app.
08-11-2021
18:07
04:24
08-11-2021
18:07
04:24
It’s good to see you in the community, @katatpeace.
Thank you for joining the thread and sharing your experience. I appreciate your efforts and feedback. I was able to see that you have already contacted our Support team, please continue working with them. I know they will be glad to help you out and provide a solution.
Meanwhile, you can try doing the following:
For complete troubleshooting tips, see Why can't I set up my Fitbit device?
Hope this helps.
14:42
04:24
08-13-2021
14:42
04:24
Thank you for your reply, @katatpeace.
I appreciate the update and thank you for sharing your concern. I am sure our Support team will do their best to help you. Please continue working with them since they have already all the details and special tools to continue assisting you. Meanwhile, I recommend keeping your app up-to-date as updates come with new features and bug fixes: How do I update the Fitbit app?
See you around.
