08-11-2022
05:01
14:01
08-11-2022
05:01
14:01
The most important Fitbit feature to me is seeing my steps on the first screen. I’ve only found this on the Charge 2. Does anyone know if this Is available on any other model?
Hi, @NolaTim , you have posted in the Charge 4 forum, so I am guessing this is a Fitbit that you are considering. There are a number of clock faces that will show you the time (sometimes date as well) and steps. You can scroll through all available clock faces here .
The short answer to your question is that a clock face that will show you steps as well as time on the main screen is available on all currently available Fitbit devices so just choose the Fitbit that has the most important features for you. If you go to the Fitbit store you can compare devices.
If you find one that you like and want to make sure that it has a clock face that does what you want, just let us know which device you are considering and post again here.
I hope this helps!
Best AnswerThere are several Charge 4 clock faces which show steps on the front of the screen with no tapping. You can see the list from the link I posted above.
You might like the one called Step Date
There is also Stats Heavy which I like.
Best AnswerThe clock face I use (which has steps on display) is the 'Retro Double Stat' one... This one shows 3 pairs of stats on the bottom half of the clock face (always leaving time and date in the top half). Just tap the screen to cycle through the pairs, if you're interested, or just leave it on the first/default one.
The pairs of stats are:
Steps & Heart Rate
Distance & Calories
Floors & Active Minutes
