03-03-2017
18:04
09:49
03-03-2017
18:04
09:49
How do you delete a custom food entry? For instance ; I logged in all the nutritional values and then realized I made a mistake with one of the mg., what should I do?
In the app, go to Log Food, then select Custom Foods. You should see an edit button. If you select Detailed View, you can edit the nutritional information for that food. I don't see a delete button, so you could either just leave it there, or change the name/nutrition to another custom food.
@WavyDavey wrote:In the app, go to Log Food, then select Custom Foods. You should see an edit button. If you select Detailed View, you can edit the nutritional information for that food. I don't see a delete button, so you could either just leave it there, or change the name/nutrition to another custom food.
So really, there is no way to delete an incorrect entry. The only "solution" is to edit it to change it into a correct entry.
