Elevation
After I'm done with my workout, my charge 2 shows the elevation when I do a hike. But it disappears after it flashes across the screen. How do I go back and see the elevation I used?
if I track the hike through my Fitbit app on my phone will it show the elevation so I can refer back to it?
25 REPLIES 25
@SunsetRunner, if you are using the Connected GPS feature of the Charge 2 for the Hike, the Elevations will show on the bottom righthand corner of the map that is generated.
Will it only show elevation if I'm
On hike through connected GPS? What if I'm on walk or run?
Kay Piña Musical Arts Center of San Antonio Inc. Music Teacher- Piano
Eurhythmics Specialist (512) 686-8529 KayLPina@gmail.com
@SunsetRunner, if you use any of the exercise modes that has Connected GPS, it will include elevation on the map. Those exercises include Walk, Run, Hike, and Bike.
Thank you! I am able to see it on the website Fitbit "dashboard" when I
look at the map. Is there a way to see it on the app itself?
Yes there is - open the Weekly Exercise tile and any exercises that were mapped will show the map under there.
Hoping you can help me. When I've been on  a walk I've recorded it by setting the fitbit charge 2 to hike and having my phone with me with the GPS on. After the walk i can see on the fitbit all the info including elevation in feet. When I go onto the app and go into weekly exercise and click on the activity I see the map and click on it but there is no reference to elevation in the map or within the details of the activity. Am I missing something? How do I find out on the app the elevation walked or even in floors for that particular walk?
Thanks
@Sunshine123 my understanding, as @SunsetRunner points out, the elavation will show at www.fivit.xom/activities
To look for elevation on hikes I have to go online on my phone. Once it
passed by on your Fitbit you won't be able to see it again on your Fitbit
or on the app. Only online.
Thank you so much. Managed to find it 🙂 delighted
Sent from Samsung Mobile on O2
Thank you 🙂 appreciate your help.
But what about when you're in an area with no cell service while hiking? My Fitbit still tells me my elevation data when I'm finished, but it doesn't show up anywhere else. Other apps using gps still work while in airplane mode.
I was wondering the same thing about elevation during my runs. I have it connected via GPS, but I do not see the elevation anywhere in the app including on the generated map itself. I have the Charge 2. Where else might I find it since it is not showing there?
    check the map through the web based page.
That did the trick! Thanks!
It will show up for a second if you’re on hike mode, but it won’t stay on
your Fitbit once you leave the hike mode screen.
If you want to look it up regularly, you have to login on line through a
web browser. I do it on my phone.
Is there anyway to see the elevation for an exercise on the app without having to go on the web or did FitBit choose to not put the elevation on the app for whatever reason
@Vincent203 this question has been answered above. No the web is needed to see elevation.
Unfortunately I’ve never seen it on the app, only as a quick flash on the
actual Fitbit right after a workout, or on the web.
Hi,
I feel that it is a major design flaw having to go online to see it when the data must be recorded within the workout. Is there any plans to implement this in the app? Would be so usefull instead of going to an external site...
