01-09-2018
09:17
17:03
DavideFitbit
01-09-2018
09:17
17:03
DavideFitbit
The heart rate only shows two dashed lines, sometimes if I press the button while on heart rate screen the heart will go from a heart outline and two dashed lines to being filled in and it will say "60 resting" but it never says anything else. Ive reset it a bunch, ive even reset it multiple times in a row. I've turned the heart rate from Auto to on and even if I turn the heart rate off it will still only display "60 resting" when I press the button on the heart rate screen. I've even got my heart rate up and it still doesn't say anything other than 60 resting
Moderator edit: format
01-09-2018 18:43
01-09-2018 18:43
I've also tried every combination of placenent and how loose or tight it is and it's doesn't make a difference
Best Answer01-09-2018 19:06 - edited 01-09-2018 19:07
Same problem started 2 days ago. Heart rate does not work and not able to track sleep pattern. Firmware apparent using the newest one.
Best Answer03-16-2019 14:32
03-16-2019 14:32
Did you ever figure a solution? Mine is doing the exact same thing.
Best Answer03-17-2019 11:31
03-17-2019 11:31
03-18-2019 05:20
03-18-2019 05:20
