12-27-2018
12:57
18:22
12-27-2018
12:57
18:22
Hi,
I wonder can you assist me in an issue that I am encountering with my Fit Bit charge 2.
The screen is permanently frozen. I let the battery die but if I charge it the same screen appears again and I cannot reset the device as the screen is frozen!
The watch is still capturing my steps (I know this because I can still sync with the phone app however I cannot use it as a watch anymore)
I have had the watch for 2 years is there a life spam to this product where it stops working after a period of time?
Thanks in advance for any assistance you can provide.
I restart should still be possible even if you can't see the screen. Can I just check that this is the restart procedure you are following:
This procedure is known to not always work so it's worth trying a few times. If that doesn't help then it's probably best to contact customer support via contact.fitbit.com If they can't help, they can check your warranty status (some countries have a 2 year warranty) and advise on your options.
Best AnswerHi @SteveH
I am following the process that you provided however it does not do anything... (Have tried it a few times now)
Will reach out to the support link you provided and ask can they assist me.
Thanks for the advice.
Thanks for your answer. This worked great for my Charge 2. I thought it was ruined. I just plugged it in, like you suggested, and pressed and held the button for 4 seconds. Bingo! It came back to life!
Best AnswerI don't understand how you were able to fix it.
ive tried re-syncing through the App. Also holding down the button MULTIPLE times, and Nothing!
Did u press and hold the button with some sort of tool when it was charging
Any insight is greatly appreciated!!
Kitty
Best AnswerTry this. It worked for me. With the frozen Fitbit 2 in the charger, I was able to press the button by using a pen. The pen was able to go through the small hole in the charger. I pressed the button using the pen for four or five seconds, and my frozen Fitbit 2 came back to life!
Best AnswerI have tried all of the suggestions and mine is still frozen. Called customer support and tried everything they said... still frozen. I’ve only had it a year and a half, so it is out of warranty. All Fitbit could do is send me a coupon towards another Fitbit. Unacceptable!
Same thing happened to me but I've had my Charge 2 for 3 years so it is more excusable. If I only had it for a year a half, I would be upset.
I think I'm just going to go ahead and use their coupon to get a Charge 3.
EDIT: It's interesting because it does appear to still be tracking. I can sync the app and it shows the steps I've made that day. Only the face of the FitBit on my wrist is frozen. So technically it still works, it just has a frozen screen. It won't turn off plugged in or not.
Can you explain how you used the tool and how it is different than just pressing the button with your fingers?
Best AnswerMine has the same problem. Restarts while plugged in didn't solve anything while the display showed the time and date from 2 days prior. So I let the battery drain completely. Now the screen displays a scattered mosaic of pixels. I've had mine 3 years, but since this is a known issue, Fitbit needs to fix the firmware or compensate its customers somehow. It still works internally, for synching up data later, but it's useless as a watch.
05-26-2020
08:48
16:31
AndreaFitbit
05-26-2020
08:48
16:31
AndreaFitbit
i am encountering the same problem.
Moderator edit: format.
Best AnswerSo, I'm done with fitbit. I really enjoyed the features and there was sentimental value in that my now deceased sister gave it to me as a birthday gift as a QVC purchase. She died 1 day before the birthday. It doesn't make sense to buy another one. Stay Covid-19 safe.
Best AnswerI have tried restarting the device a few times. Only the clock face appears and then goes off. There's a vibration heard but nothing more than the clock face. Is there anything else I can try that you suggest?
