06-11-2016
05:49
17:01
06-11-2016
05:49
17:01
I'm on my second FitBit Charge. The strap on the first one completely fell apart... after 4 months... bubbles then tears... so I was thrilled when I was sent a replacement! And 4 months... bubbles, tears and it has to be reset every day or it won't sync.
What is going on!?!? When I bought my first one, it was over $100. If I have to buy a new one every year- I may as well get a cheaper brand!
I am just fed up. I thought it was the greatest thing, until 4 months.
Any suggestions?
Moderator edit: Capitalization and subject clarity
06-11-2016 07:51
06-11-2016 07:51
Hi @nwieme
Feel free to contact the Fitbit Support Team (Click / Tap here to contact) once more.
Optionally check out Returns & Warranty before contacting support.
Best Answer06-11-2016 08:20
06-11-2016 08:20
I know someone who has had the same problem with their Charge. I used to have Charge before I upgraded to the Alta and it is still fine. Not all people have that problem but quite a lot do. The reason I got the Alta is because you can change the bands like the Blaze which is very handy and helpful.
Best Answer06-11-2016 08:41
06-11-2016 08:41
fitbit charge hr is not durable at all. the battery does NOT last up to 5 days and it falls apart too easily. first one came apart by thew charge plug.within 1 year was replaced, 2nd one only lasted 6 months! i took very good care of this device and fitbit would only give me 25% off a new device. who wants to spend $149.00 every year for a product that does not withstand everyday use. I am DONE with fitbit. they claim they back their product but they do not.
Best Answer06-12-2016 10:43
06-12-2016 10:43
I've had 4 or 5 replacements in 8 months. Support is useless, every moderator here says they're great and they will definitely help but they don't. All you get, if you're lucky, is a replacement of the same poor quality.
06-12-2016 11:01
06-12-2016 11:01
07-12-2019 06:14
07-12-2019 06:14
I switched from Charge to Alta (after 2 Charges stopped working) and now the Alta is DEAD DEAD DEAD. I'm frustrated. I can't even find where to post my problem.
Best Answer08-12-2019 00:28
08-12-2019 00:28
Where can I purchase a small genuine charge 2 wristband
