02-01-2020
07:46
17:16
02-01-2020
07:46
17:16
My Fitbit help is in Chinese how can I change it? Where do I find the spot to change weather locations?
02-02-2020
06:46
08:07
02-02-2020
06:46
08:07
It's great to see you around, @CheryPask.
Regarding your inquiry, I recommend taking a look at the following help articles and follow the instructions provided there:
Keep in mind that the language on the device you are using has to be the one you prefer too.
Let me know the outcome. 🙂
10:35
08:06
02-03-2020
10:35
08:06
Thanks for getting back, @CheryPask.
How are you viewing the help articles? If you are on a desktop, you just need to scroll down to the bottom and right hand side and switch the language?.
Keep me posted.
