09-30-2016
14:31
11:38
09-30-2016
14:31
11:38
Hi,
Can someone tell me how to manually tell your charge that you plan to sleep? Mine keeps recording that it is taking 0 minutes to get to sleep when Using the auto recognition function, which I know isn't the case. I saw on here a suggestion to manually put it in to sleep mode which might give a more accurate representation.
Very new to Fitbit (48hrs!!) and the app and I can't see a way to do it, can anyone help please?
09-30-2016 14:33
09-30-2016 14:33
Best Answer09-30-2016 15:25
09-30-2016 15:25
Hi @Bex1225, I think that I can help.
So there isn't a way to put the Charge 2 into sleep mode from the tracker itself, but you can start and stop a sleep log on the Fitbit App by following the instructions listed here.
Let me know if you need any additional help and welcome to the Fitbit Community!
Best Answer09-30-2016 23:51
09-30-2016 23:51
Best Answer06-16-2020 12:43
06-16-2020 12:43
FIT BIT 2: All functions working fine except sleep mode is not registering. Will it help to re-set the FIT BIT 2?
