11-02-2018
08:44
15:03
11-02-2018
08:44
15:03
How do I keep the clock as my main screen on the Fitbit Charge 3? Right now I cant get out of the stay awake/notifications screen. I try to swipe up/down, left/right and nothing happens.
06-04-2019 14:50
06-04-2019 14:50
That's useful, but the designers seem to ignore two factors...
When on a 3 hour flight, with no access to a usb port or power outlet, you are out of luck.
And, not everyone has fingernails long enough to successfully push the indent area (certainly it is not a button) for eight seconds or more. A pen works, but that seems like a MacGyver solution.
Best Answer06-04-2019 16:01
06-04-2019 16:01
Best Answer07-23-2019 11:50
07-23-2019 11:50
I had a bit of effort putting together the info from the other replies (that is everyone!)
On the charge 3, it's an easy gentle touch on the sides (with haptic vibe to let you know its accepted) to get back to the previous screen. Wait a sec, touch both sides of the fitbit face again to get to the next previous screen.
So, I went 4 screens deep and had to touch gently (no squeezing or nails needed) 4 times to get back to the clock, waiting a moment between each new screen.
Hth!
08-09-2019 02:34
08-09-2019 02:34
My clock is showing the wrong time how do I fix it
Best Answer08-30-2019 09:24
08-30-2019 09:24
Going into the settings on your fitbit app will fix it
Best Answer08-30-2019 10:04
08-30-2019 10:04
well it soes not. When I finally get the clock it will no longer show when I raise my hand. It vibrates every 20 seconds or so for no apparent reason. I want to see my steps and the time. It also does not reset steps to zero at midnight.
Best Answer09-12-2019 13:58
09-12-2019 13:58
Have tried attaching to charger and also holding sides but unable to get clock back on home screen
Best Answer09-12-2019 14:00
09-12-2019 14:00
This must be a problem with the Fitbit if a recurring problem in 2019?
Best Answer09-12-2019 14:12 - last edited on 07-02-2020 12:52 by LiliyaFitbit
agree extremely frustrating
Moderator edit: format
Best Answer09-16-2019 15:13
09-16-2019 15:13
Finally your suggestion worked perfectly. Thank you
Best Answer10-12-2019 12:36
10-12-2019 12:36
Thanks..just second day of my fitbit and some exercise routine started and was not ending that too at midnight..just followed what u suggested so got the smiley and home screen back
Best Answer10-26-2019 19:46
10-26-2019 19:46
Which side is the button on and how do I work it? I have no idea.
Best Answer10-26-2019 19:57
10-26-2019 19:57
Best Answer10-26-2019 20:07
10-26-2019 20:07
Best Answer10-26-2019 21:51
10-26-2019 21:51
This worked like a charm!! 😊
Best Answer10-27-2019 04:20
10-27-2019 04:20
Best Answer10-27-2019 08:02
10-27-2019 08:02
Best Answer10-28-2019 06:29
10-28-2019 06:29
I can't believe they don't put this in the user manual.
Best Answer10-28-2019 07:08
10-28-2019 07:08
Best Answer10-28-2019 07:34
10-28-2019 07:34
