12-22-2020
01:01
16:17
12-22-2020
01:01
16:17
Does the charge 4 track a vibration plate exercise accurately and if so under what type of workout?
12-22-2020 05:04
12-22-2020 05:04
Hello @SunsetRunner and welcome to the Help forums. I did a little searching in the Help forums to look for other user's experience with a vibration plate. My first thought was that the Charge 4 might pick up the vibration as steps, making it useless. That doesn't seem to be the case. I recommend either Pilates (this is a bodyweight exercise) or Workout.
Laurie | Maryland
12-22-2020 05:04
12-22-2020 05:04
Laurie | Maryland
12-23-2020 03:34
12-23-2020 03:34
Welcome to the Community, @SunsetRunner and @LZeeW, thanks for the input.
I am glad to see here that our friend replied to your exercise inquiry and that the reply was marked as best answer. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up!
Best Answer05-01-2021 07:06
05-01-2021 07:06
This answer does not help. How would I track a vibration plate exercise on a fitbit charge 4
Best Answer05-01-2021 11:32
05-01-2021 11:32
Hello @TR1989 and welcome to the Help forum. Fitbit recommends that activities that don't have their own exercise shortcut should be tracked using the Workout choice. Can you explain why this doesn't work for you?
Laurie | Maryland
Best Answer05-01-2021 11:53
05-01-2021 11:53
Best Answer10-25-2022 21:30
10-25-2022 21:30
I select the calisthenics exercise. That’s the closest I could come up with.
