04-02-2018
11:44
18:54
04-02-2018
11:44
18:54
Hi Fitbit community i was doing a hike to day and started a hike exercise. When I finished the hike i noticed that instead of floors it had meters. So I asked my self and google if there was any way to change floors to meters because I would love to know how far I climbed in meters more than floors. As it takes some time to work out how far i climbed. Kind regards Jdragon25
04-03-2018 08:49
04-03-2018 08:49
Hey @JDRAGON25, welcome aboard!
The altimeter can only count floors when it detects raise in elevation of about 10 feet or more, then this is gonna be considered as a floor just like my friend @SunsetRunner mentioned.
Now if you are talking about the elevation gain, then this is a different option, you can see it on the tracker itself once you finish your hike, or other activity like walk or run, and that one appears in meters, but that is the only one. So just to confirm, I'd like you to tell me if this is the one you are talking about. ![]()
Keep me posted!
04-03-2018 08:12
04-03-2018 08:12
The trackers count every raise in elevation of about 10 feet or more as a floor. They are not designed to count feet, yards or meters. They are actually using an altimeter to note the change is air pressure.
04-03-2018 08:49
04-03-2018 08:49
Keep me posted!
04-06-2018 09:37
04-09-2018 05:39
04-09-2018 05:39
You are more than welcome my friend @JDRAGON25! Sounds pretty awesome that the information that I posted above, helped you out. If you have further questions or comments, let me know!
Have a nice day!
Best Answer05-06-2019 09:39
05-06-2019 09:39
I have just finished a off road bike ride. On my Charge 2 on my wrist it tells me how many metres I have climbed.
When I go to the fit bit dashboard both on my phone and mac it does not show how many metres I climbed!
Is there something I can do to show this data
