01-09-2020
11:56
16:58
01-09-2020
11:56
16:58
Hi,
Got my Charge 3 as a Christmas present and wanted to finally set it up, but I tried to do it as suggested with the Fitbit connect software but the Charge 3 is not listed there. In a briefly available screen it is written Mobile only.
Anyone knows how to setup a Charge 3 on a Mac computer? My iPhone 5 does not support iOS11 so I cannot use the App. Any ideas for a work around?
Thanks!
Welcome to the Community, @Run1978.
If you don’t have a compatible phone or tablet, you can set up and sync most Fitbit devices on your computer with Fitbit Connect.
Fitbit Connect is a free software application that lets your Fitbit device sync its data with your fitbit.com dashboard. To learn more about the fitbit.com dashboard, see the article: About the fitbit.com dashboard.
If your computer isn’t Bluetooth-enabled, you must use a wireless sync dongle to set up and sync your Fitbit device. Most Fitbit devices don’t come with a dongle, but you can buy one from the Fitbit Store, but I recommend using the Fitbit app if you can.
To install Fitbit Connect and set up your device:
If you have trouble, I recommend taking a look at the help article: Why can't I set up my Fitbit device?.
Let me know the outcome. 🙂
