10-04-2018
04:42
15:47
10-04-2018
04:42
15:47
Does anyone know what sports are on the new charge 3? I’m trying to get rowing, you know on a concept 3 static rowing machine Been trying to find a tracker that has it on there I use the static machine figuring the week then on the water st weekends
Moderator Edit: Updated Subject for Clarity
10-04-2018
08:29
09:37
10-04-2018
08:29
09:37
@Derrick241 I hope you're doing well! Thanks for your interest in Charge 3 and for taking the time to post your inquiry about the sports it includes on its Exercise Shortcuts specifically rowing.
Rowing is not available as an Exercise Shortcut for Charge 3. However, you can vote for the following Feature Suggestion:
It is showing as Under Consideration so that is a good sign. If the suggestions doesn't fill what you are looking for; feel free to post a new suggestion, something like outdoor rowing or just rowing.
Also, for the moment, you can manually log rowing as an exercise using the Fitbit app or dashboard.
These are the activities available on Charge 3 Exercise Shortcuts:
Hope this helps. Keep me posted! ![]()
02-03-2020 05:11
02-03-2020 05:11
The link "manually log rowing as an exercise" is broken, returning "Error: Error ID: 2093732835-45519 (-1729621941)"...
Best Answer02-03-2020 06:51
02-03-2020 06:51
@SunsetRunnerInteresting, it's likely a transient problem. I've just tried and the link is working, https://help.fitbit.com/articles/en_US/Help_article/1785
