03-12-2019
12:43
17:14
03-12-2019
12:43
17:14
My green led lights on back of fit bit are no longer flashing, there for I cannot get a heartbeat reading, only resting heartrate.
Does anyone know why they would stop flashing on the back of fitbit.
03-13-2019 00:18 - edited 03-13-2019 00:34
@Jim5999 Welcome to the Community. Have a check in your App settings to see if the heart rate is set to switched off. To do this go into your App dashboard, tap on the account icon top right, select your Charge 2 from the device list and scroll down to Heart Rate. If you find its switched to off change it to Auto or On and then resync your tracker.
I would also suggest doing at least 2 reboots too, you can do this by popping your Charge 2 on its charger and press and hold the button in for 4 seconds which will trigger a restart once complete you will get a buzz from the tracker to confirm its done.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
Best Answer03-13-2019 04:32
03-13-2019 04:32
Best Answer03-13-2019 09:39 - edited 03-13-2019 09:53
Thanks for trying Jim, I found this previous thread you could give this a go unpairing and repairing to your Fitbit bit app, if it's not successful I would suggest contacting Customer Support so they can provide some further assistance with diagnosing the issue.
Tony | UK
