09-04-2020
03:53
09:08
09-04-2020
03:53
09:08
I lost my Charge 4 today. I did not notice until I returned home. Thank goodness, I still have my Charge 2, which has the same problem. I will keep it in my pocket when not in the house. So now i need to purchase another tracker. Maybe it is time to buy another brand as Fitbit has a strap probkem.
09-04-2020 18:39
09-04-2020 18:39
Hi @Sparkling73, welcome to the Community Forums!
Thanks for bringing this to our attention, seems odd that your two Fitbit devices experienced the same issue but I'm sorry to know that you lost them. I recommend the following tips to find them:
Let me know if you still can't find your devices in a few days so we can move on.
Best Answer09-06-2020 17:30
09-06-2020 17:30
Mine has done this, the band came unhooked from the Fitbit. At first I thought that the little square bump that is on the Fitbit side is worn down so that it does not hold in the matching indent on the band side.
Upon further inspection I see that the little rubber pieces on either side of the latch, on the band itself, are halfway loose from the band. I will try some superglue.
The Fitbit itself works just fine, as always.
09-07-2020 06:03
09-07-2020 06:03
09-09-2020 18:06
09-09-2020 18:06
Best Answer04-01-2021 12:35
04-01-2021 12:35
This happens to me all the time, and eventually lost mine. This started about a month after bought it and kept the reflective band that came with my fitbit charge 4. Thought maybe it was a fluke and used the standard rubber band for a little bit, that was way too hot. same thing happened then. Bought a 3rd party metal band with a magnetic clasp. Welp, while moving my wife's parents into their new place the Fitbit charge 4 disconnected from 1 side of the band and fell off. I only noticed when I got home.
I did panic a little bit, but pulled up the Fitbit app saw when it was last synced with my phone, then used the google location history of my phone to see where I was at during the last sync. I think this is going to be my first and last fitbit product. Been looking at smart wrist accessories that will not fall off my wrist and can withstand daily punishment.
I luckily found it, but now really nervous that I cant trust that it will stay on my wrist through normal every day activities yet alone exercising or being on the water, where it ill just sink
