01-10-2019
20:14
17:54
01-10-2019
20:14
17:54
Charge 2 information says I can press button in, and just tap clock to go to next screen. It doesn't work?
Press button again to go to next screen
Manual is here and can help a lot
https://staticcs.fitbit.com/content/assets/help/manuals/manual_charge_2_en_US.pdf
Wendy | CA | Moto G6 Android
Best AnswerThank you. It says to tap to move thru to menu. Mine doesn't. It just automatically turns off.
Best AnswerSays to wake up screen, can double click. Tapping isn't working. Or to go to different screen. I can't figure out what I am doing wrong. Here are instructions:
When you’re not using Charge 2 the display is off. To wake it up:
Press the button
Turn your wrist towards you. This behavior, known as Quick View, can be
turned off in your tracker settings.
Double-tap your tracker.
Using the clock and menus
The default or “home” screen is a clock, which is available in several styles. On the
clock screen you can:
Tap to see your steps taken, heart rate, distance, calories burned, floors
climbed, active minutes, and hourly activity.
Press the button to move to through the menus.
Press and hold the button to turn on or turn off notifications, including
