01-01-2021 08:17
01-01-2021 08:17
Phone will not update fitbit, phone message reads This feature is not available on this device
Is it possible to update fitbit another way ?
01-01-2021 08:30
01-01-2021 08:30
@Alan1234 - I’m concerned because your phone is not on the list of Supported Devices. The first thing to check is to make sure your phone’s OS is on 7.0 or higher. Then, check to see if your Fitbit app is up to date. That may help.
But to answer your question, you can try updating your Charge using these instructions on updating from the Fitbit.com dashboard. Please let us know if you are successful.
Best Answer01-01-2021 08:30
01-01-2021 08:30
Best Answer01-02-2021 09:50
01-02-2021 09:50
Best Answer01-02-2021 09:52
01-02-2021 09:52
Thanks for your advice have posted my reply onto the forum page
Best Answer01-02-2021 09:55
01-02-2021 09:55
Forgot to say phone's OS is 10
