05-18-2019
22:28
19:58
05-18-2019
22:28
19:58
Do I need converter to charge Fitbit in Israel or just an adapter plug.
05-19-2019 11:14
05-19-2019 11:14
I believe you just need an adapter plug, @Holyghost . But you may want to check with Support, just to be sure. I’ve never been to Israel but the adapter was all I needed in France.
Best Answer05-19-2019 14:51
05-19-2019 14:51
05-22-2019 12:56
05-22-2019 12:56
Basically the Charge HR just needs a standard USB Charging port @Holyghost
Most any phone charger will work, since most are designed to work with voltages between 100 and 240. Check the label on the wall brick. So yes as @SunsetRunner says an adapter allowing the phone charger to plug into their outlet will be fine.
05-22-2019 16:30
05-22-2019 16:30
