04-10-2022
02:44
14:39
04-10-2022
02:44
14:39
I have a replacement fitbit and can't sync it to my app. Can't get it to work at all. Fitbit says download or update the fitbit app to set up. I have tried updating the app - it says it is syncing but nothing happens. Can anyone help?
04-10-2022
03:29
09:56
04-10-2022
03:29
09:56
Hi, @Sal3pink , have you actually connected it to your account? When the app is updated you need to open the app and click on the small person icon/photograph top left - that takes you to the account screen. On the account screen scroll down to + set up a Device.
On the set up screen choose Charge 4. You will get a message saying there is already a charge 4 connected to your account; do you want to replace it? Confirm that you do and follow the instructions from there.
If you still have your old Charge 4 you may want to move it out of Bluetooth range if the app is having trouble finding your replacement charge 4.
I hope this helps. Welcome to the forums!
04-10-2022 04:53
04-10-2022 04:53
Hi Julia. Thank you SO much!! That's got it working properly. I really appreciate you taking the time to help me.
Best Answer04-10-2022 06:05
04-10-2022 06:05
@Sal3pink , excellent! I am so glad that the solution was simple and that worked for you!
