05-13-2020
09:37
16:20
05-13-2020
09:37
16:20
I just replaced my broken charge 3 with a charge 4. I am unable to get the quick view to work, ya know when you rotate your wrist to see the time. I've taken the "sleep" mode off on the fitbit itself but it still isn't working. Please help, so frustrated 🤦
05-15-2020
16:11
14:08
05-15-2020
16:11
14:08
Hi @Kreed53, welcome to the Community Forums! Sorry for the delay in responding your post.
Thanks for bringing this to our attention and for trying some troubleshooting steps before posting, I understand how frustrating this matter can be for you. To resolve this issue, I recommend you to restart your Charge 4 and make sure that the QuickView feature is currently on following the next steps:
Looking forward to your reply if further assistance is needed.
09-15-2020 15:44 - edited 09-15-2020 15:48
Hi, I'm having the same issue with Fitbit Charge 4 Quick View not working. Everything else is fine. Sleep mode is off. I've restarted. I do steps 1 and 2, but do not see an option for Quick View after I tap Charge 4 image. Apparently rebooting twice does the trick. Mine is good now.
Best Answer10-05-2020 07:32
10-05-2020 07:32
This is driving me mad as I am unable to see the time at anytime or data when doing exercise, When I move my wrist to try and see the time this only happens sometimes! I have to touch the side and then that pauses the exercise and as Im unable to see the screen I don't realise its paused and then the correct workout isn't recorded. I have done all the above but unable to find Quick View and sleep and DND is turned off from my phone. I have rebooted and still nothing changed. Can you advise what to do now?
Best Answer10-08-2020 13:00
10-08-2020 13:00
there is no quick view following these steps either in the app or the fitbit dashboard for charge 4
10-28-2020 02:50
10-28-2020 02:50
hes right i could turn it on not off
Best Answer01-22-2021 02:03
01-22-2021 02:03
So for the charge 4 there are no settings for this in the app. You have to change this setting on your fitbit as follows: hold the button on the side for a few seconds and a new screen will pop up. Then scroll to 'screen wake' and turn it off, that should do the trick!
01-31-2021 12:51
01-31-2021 12:51
There is no account icon on the Fitbapp dashboard?
Best Answer01-31-2021 13:20
01-31-2021 13:20
I tried rebooting twice and it failed to fix the problem; Charge 4 Quick View not working.
02-02-2021 11:03
02-02-2021 11:03
Thank you! This worked for me.
10-16-2021 08:32
10-16-2021 08:32
I agree with this procedure. After numerous attempts to turn off this annoying light turning on at night. All the chats seemed to be old methods. By accident I was trying to reset my charge 4. I pressed the left side button fir a few second a the turn off wake function appeared.
10-17-2021 07:27
10-17-2021 07:27
Welcome to the Fitbit Community, @sd8.
Thank you for joining the thread and sharing your experience. I understand how you are feeling and appreciate your feedback. Our team is always working on our products and services, and your comments are always welcome. I am glad to hear that you were able to fix this issue and thank you for sharing what you did as it may help other members in the same situation.
In case you have some spare time, I would like to invite you to visit our Discussions board where you can share your experiences, make new friends and create new topics.
See you around.
Best Answer12-01-2021 13:33
12-01-2021 13:33
Please expound on number 3
12-01-2021 13:33
What do you mean with number 3? I can't find that option
Best Answer12-01-2021 13:34
12-01-2021 13:34
Mine just goes into "Tap to unlock" when I hold that button down
Best Answer04-09-2022 20:43
04-09-2022 20:43
For Charge 4 users. This is the option that works
Best Answer07-09-2022 12:52
07-09-2022 12:52
THANK YOU!!!!
Best Answer11-22-2022 02:38
11-22-2022 02:38
With the Charge 4 you have to hold the button down for a few seconds and a menu will appear. If you have a payment card loaded on your Fitbit it will bring up that screen and you need to scroll to the wake settings page (left) at the bottom is the wake toggle button. This menu should appear as the only menu if you aren't using a credit card.
So frustrating that this turned off on it's own, but I'm glad this fixed it finally.
