12-31-2020 08:29
12-31-2020 08:29
Anyone know if Fitbit will ever fix the charge 3 brightness problem? I’ve rebooted and checked brightness settings but it still doesn’t work. It’s clearly a very well known problem but no solution seems available. It’s a shame because the app is good. If there’s no fix I will be buying a different brand of fitness tracker and never return to Fitbit!!
12-31-2020 08:35
12-31-2020 08:35
"It’s clearly a very well known problem"
Not known to me, but I will guess the display is too dim for you. Have you checked that you are not in Sleep Mode, intentionally keeping brightness dim?
Best Answer12-31-2020 08:50
12-31-2020 08:50
Best Answer12-31-2020 13:55
12-31-2020 13:55
The display on my Charge 3 occasionally decides to go dim. To fix the problem I need to go indoors where the ambient light is less than outside so that I can see the dull screen. Then from the normal display:
This has always worked for my Charge 3 and for my wife’s Charge 3. I would avoid the “Auto” Brightness setting as this does cause the display to change. Using the fixed “Normal” brightness setting seems to be better.
Best Answer12-31-2020 14:02
12-31-2020 14:02
