02-10-2021
11:09
10:36
WilsonFitbit
02-10-2021
11:09
10:36
WilsonFitbit
Can not tap screen and have it turn on.
Also screen brightness is why to low can barely see it even in a dark room. And I have 66% on battery. Not sure how to fix this
02-10-2021 11:10
02-10-2021 11:10
Make sure sleep mode is off and screen wake is on. Also, you can change the screen brightness in the device settings.
02-10-2021 17:21
02-10-2021 17:21
thank you! somehow my brightness got switched to low. Not so easy to find the settings when you can't see the screen but i was able to manage it
thanks for the advice 😊
02-11-2021 10:35
02-11-2021 10:35
Hello @HEATHER95, @Caroline_G, welcome to the community forums! @Mrb731 it's nice to see you around and I appreciate your input!
@Caroline_G I'm glad to hear that the instructions provided, helped to resolve your question. I recommend marking the answer given by @Mrb731 as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
@HEATHER95 as @Mrb731 mentioned, you can change the brightness on the settings on your Charge 3. If you haven't done so, I recommend following the steps below:
For your comment, are you referring that your Charge 3 doesn't respond to taps? You may try to perform a restart as well.
I'll be around.
