03-08-2017 00:19 - last edited on 09-09-2020 09:49 by MatthewFitbit
Charged overnight. Screen showing full battery but it's stuck and won't sync to phone either. The green lights aren't flashing on the back. I'm in the middle of a step challenge for Cancer Research and need my Fitbit. Help!
03-08-2017 00:53
03-08-2017 00:53
First thing to try when a fitbit misbehaves is a restart using this procedure:
https://help.fitbit.com/articles/en_US/Help_article/1186/
It does no harm and can sort out all sorts of issues. Give it a few tries though as it doesn't always work.
03-08-2017 00:53
03-08-2017 00:53
03-08-2017 08:33
03-08-2017 08:33
Thank you Steve. I'm up and running again!
01-11-2019 10:30
01-11-2019 10:30
I'm stuck on the charging screen but can't restart by holding the buttons
12-25-2019 13:06
12-25-2019 13:06
Were you able to get your One off the battery screen and working again? My One is also stuck on battery and the several suggested ways to get it working again just aren’t. I’m on day three of it being on battery. It “syncs” to my updated iPhone but does not show any steps etc. thanks!
12-30-2019 15:57
12-30-2019 15:57
Hi, did you ever get this sorted as I’m in exactly the same position. The automatic shutdown is not working by pressing the two buttons for 10 secs 😔
12-30-2019 17:08
12-30-2019 17:08
06-26-2020 05:05 - edited 06-26-2020 05:09
Me too. Stuck on battery icon and won't budge. Reset no difference. Uninstalled and reinstalled app no difference. Pressing the button for 10-12 seconds no difference.
Sorry Fitbit, you are just not that helpful in resolving these issues. We're all trying to help each other but get basically nowhere without Fitbit intel.
06-26-2020 05:39
06-26-2020 05:39
Hi, @jjthink , you have posted in the Charge 2, Blaze, and Alta HR forums. In order to give you the best advice, we need to know what kind of Fitbit you have (the restart procedures differ)
06-26-2020 05:49
06-26-2020 05:49
Hi. I apologize. I should have included that info. It's an Alta HR.
10-25-2020 16:48
10-25-2020 16:48
Thank you, I got my watch going again after following your advice.
