04-23-2021
12:13
04:16
WilsonFitbit
04-23-2021
12:13
04:16
WilsonFitbit
Over the last year my Charge 3 have lost A LOT of features.
- I have set the alarms - and none is working
- I have set the notice to move each hour - it is not working (that's why I set the alarms, to get some kind of notice)
- I used to get some kind of gratulation when I reached the 10.000 steps for today - I don't get it anymore
- the last month or so when I synchronize I get like 35.000 or even 85.000 steps ..... after synchronized 3-4 times it gets the right number of steps.
So could someone please restore the old and working software????
By the way, if I search for Charge 3 on the Fitbit homepage it is impossible to find - wonder why.......
Moderator edit: subject for clarity/format
04-23-2021 13:09
04-23-2021 13:09
It sounds to me like your settings got changed rather than Charge 3 having lost features.
Maybe you are in Sleep Mode or have Do Not Disturb turned on.
I'm not sure what you mean by looking for Charge 3 on Fitbit home page. If you mean the Fitbit Store, Charge 3 has been discontinued since the Charge 4.
If you mean as a Product Help Forum, it is in with Other Charge Trackers (other than Charge 4).
04-23-2021 13:09
04-23-2021 13:09
04-23-2021 23:52
04-23-2021 23:52
Sleep and Do not disturp was set. So problem solved - thanks a lot. And .... as I dig down in my memory I think that was about the time my son was looking and playing with my watch. He's like 'what happens if I press this?'
And about looking for Fitbit store, yes, but why not showing information about a watchs that I can still buy???? I don't get it.
Now I will cross my fingers that I can syncronize the watch, I can see that a lot of people have the same problem as I have about not syncronizing or showing way too high number of steps.
Best Answer04-26-2021 06:28
04-26-2021 06:28
Hello @TheOldLady. It's great to see you around! @JohnnyRow I'm also glad to see you around and thanks for your input!
I'm happy to know that the instructions provided by @JohnnyRow helped to resolve your concern. In regards with your inquiry for information about Fitbit watches, I recommend visiting the following link: https://www.fitbit.com/global/us/products/find-your-fit.
On a side note, please note that your feedback is very important and it helps to continue working on improvements to our services and products.
See you around.
