02-25-2017
05:53
10:13
02-25-2017
05:53
10:13
I work out on a stairmaster almost every day. The way I have to enter it is to use the web dashboard (not the app), click on Log>Activities>Walk and then manually enter all info, every single time. I know the Fitbit won't pick up the activity but is there a way I can create and save a shortcut?
@Kabar, thanks for joining the community!
Unfortunately, you cannot create your own workouts or shortcuts on the Fitbit App. However, on a Stairmaster, I would suggest using the "Walk" or "Treadmill" shortcut.
Fitbit sometimes also picks up when you are doing other activities, like Sports.
Hope this helps!
Yes, there is. If you go into settings for the tracker in the dashboard, there is a section called "exercise shortcuts". You can have up to 7 shortcuts listed. If you have 7, remove one you don't use. Then you can add a shortcut...and Stair Climber is already one of the defined ones! Just add that exercise, and it will show up on your tracker after that. Enjoy.
Does this short cut still apply in 2019? I can’t seem to figure it out.
Best AnswerDoes this still apply to 2019 format? I can’t seem to figure it out.
