01-22-2019
10:32
17:54
01-22-2019
10:32
17:54
When doing exercise bike work, how is it best to track. ‘Bike’ option obviously doesn’t track movement as it’s static. Any ideas? Thanks
01-22-2019 10:49
01-22-2019 10:49
Welcome to the forums!
I always manually log it. I tell it what my bike says as far as miles and calories burned.
Look around the forums and join in on some of the discussions! Lot's going on!
Hope to see you around!
Wendy | CA | Moto G6 Android
01-22-2019 11:53
01-22-2019 11:53
01-22-2019 12:08
01-22-2019 12:08
@Jenko10Just to add on from what @WendyB has mentioned, you could also add spinning to your exercise shortcuts which would be better than using the bike one.
To add just go into your account in the App and select your Charge 2 and scroll down to exercise shortcuts where you can add and remove shortcuts. When done just resync for the changes to take effect on your Charge 2 and you will be good to go.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
