09-09-2019
09:58
10:43
09-09-2019
09:58
10:43
When I finish exercising I can not figure out how to stop my timer. Once I finally push something (short of throwing it across the room) it will pause and ask if I want to end... and then I can’t figure out how to end the workout. Today it took me 8 minutes to end the workout!!! The screen that keeps appearing is the ”screen brightness” and “notifications”. Help!!!
09-09-2019 12:54
09-09-2019 12:54
- If you hold the side button for too long, it will display a Screen Wake / Notifications screen, if you end up here hold the side button again until you return to the screen it was on before.
I shared your frustration the first times I tried to end an exercise, and spent a similar amount of time fighting with mine to stop it.
09-09-2019 10:55
09-09-2019 10:55
Press left "button". I forget exact sequence after that, but left button starts exit and maybe asks if you are done or just pausing or such.
Best Answer09-09-2019 12:32
09-09-2019 12:32
Thanks!!! I only have 1 button though!!!
Best Answer09-09-2019 12:35
09-09-2019 12:35
Yes, and that's the button to press, and then follow the dialog. I might include tapping different parts of screen.
Best Answer09-09-2019 12:54
09-09-2019 12:54
Thanks! I’ll keep trying. Once I’m able to find the correct button navigating is easy. It’s just finding the right way to hit the button to reach the navigation that’s really hard!! Fingers crossed!!
09-09-2019 12:54
09-28-2019 02:58
09-28-2019 02:58
Oh my gosh. My timer got to 92 hours and I've tried every bit of advise online and nothing worked until this! Thank you!
Best Answer08-15-2020 09:21
08-15-2020 09:21
I have tried your suggestion... it keeps going to Alexa and she cannot help me either!! I am going to throw this across the room!!!
